How to install STM32CubeCLT in docker container?
cla
Hello
I am new to this forum, so if I am at the wrong place, let me know.
How can this software: https://www.st.com/en/development-tools/stm32cubeclt.html be installed from a script? Namely into docker container?
I get the following error:
``` DISPLAY not set. Cannot display license. Aborting. ```
Thanks in advance.
Stefan1
Try setting this env:
LICENSE_ALREADY_ACCEPTED=1
It works for STM32CubeIDE.
6 REPLIES 6
Pavel A.
Evangelist III
What if you just install cubeclt on a normal linux machine with a display (yes, manually), then copy the stuff into container, post the result to your container server and be done with it?
Thanks for the suggestion. I will consider this.
I was wondering, though, if there is no way to do it automatically, as I would like to build the container automatically from a script as well. Is this really an edge-use-case? I would have thought, that the installer would provide a way to accept the license agreement from a script? I tried `echo y | install_script` and the like. It does not work.
If there is no way, where to post the feature request?
Thanks.
Pavel A.
Evangelist III
@SofLit could you look at this request? Is there a "legal" way to bypass the license annoyance for headless installation?
Hello @cla
First let me thank you for posting.
In fact, during the installation it's required that the license agreement is done manually by the user.
I will raise your request internally and give you updates as soon as I get them.
KR,
Semer.
Stefan1
Final command:
unzip ./en.st-stm32cubeclt_1.16.0_xxxxx.sh.zip && \
chmod +x ./st-stm32cubeclt_1.16.0_xxxxx.sh && \
echo | sudo LICENSE_ALREADY_ACCEPTED=1 ./st-stm32cubeclt_1.16.0_xxxxx.sh
`echo` sends newline to accept default install directory (there might be a better approach, but this worked).
