2021-12-22 4:22 AM
2021-12-22 4:26 AM
AN2606 describes this process for the STM32L4R in section 65. The bootloader can be activated using pattern 6 (section 4.1), which describes the possibilities for activation.
Good luck!
/Peter
<edit>As I've just seen, you've essentially asked the same question.</edit>
2021-12-22 4:26 AM
Good luck!
/Peter
2021-12-23 2:45 AM
Thank you Sir..
