am trying to connect stlink v2 debugger with stm32f413 mcu hardware in Cube programming sotware am getting Error: Cannot connect to access port 0 If you are trying to connet to a device with TrustZone enabled please try to connect with HotPlug mode
saraiahd
3 REPLIES 3
Not much information to work with here.
Suggests the chip/board aren't running.
Start by providing information about the board, how the debugger is attached, and how everything is powered
saraiahd
what is HotPlug mode do u have any idea
Aziz BRIGUI
Hello @saraiahd​,
Welcome to ST Community !
Hot Plug mode is used to connect to the target without a halt or reset. You can check STM32CubeProgrammer user manual for further details on the connection modes.
For your specific case, as stated by @Community member​, could you provide more info on how you're connecting your debugger to the target ?
Thanks,
Aziz
