When will be the stm32mp157 fully supported bu cubemx ?
PMort.1
Cannot select 8 bit wide bus for SDMMC controller (for use with e-mmc)
Cannot select USB:OTG_LS instead of USB_OTG_FS (to use 2 usb HS and the usb OTG LS togheter)
4 REPLIES 4
Khouloud ZEMMELI
​Hello @PMort.1​ ,
Thanks for your feedback,
For the second point : it's on going.
For the first point : Could you please share your ioc file ? because the 8 bits wide bus can be selected on my side.
Khouloud
PMort.1
Thanks for your reply
I have found the 8 bìt bus, it is only on the SDMMC2 controller; now i can select it (MMC 8 bits wide bus)
Paolo
​So no problem for the SDMMC ?
PMort.1
No i can choose from 1bit to 8bit for SDMMC2, without any problem.
Best regards
Paolo
