X-CUBE-EEPRMA1 package activation in CubeMX
meena
I am in work with a product firmware with STM32G030k8 with additional EEPROM M24C04 I coudlnt ble to instal the driver files .
Is this the righ tway am doing,can any one please address this?I am not able to hightlight or install Thanks.
17 REPLIES 17
Yes ,unable to do that.Sorry for the pain
Your .ioc says 6.12version and Iam unable to migrate my cubemx version for updates
What CubeMx version you are using?
 You cannot check the checkbox at the left in the CubeMx update window?
PS: This is NOT an online support (https://ols.st.com) but a collaborative space. So please be polite in your reply. Otherwise, it will be reported as inappropriate and you will be permanently blacklisted from my help/support.
Yes I cant do that .
OK.
Could you please uninstall the old version (you didn't mention the version you have) and download/install the latest version: 6.12.1?
hi the .ioc file can work for me but when I am trying to use in my development environment I could'nt able to check/instal  the driver package.
Content restored.
SofLit
I've unmarked the solution.
Unfortunately, the resolution of the images you shared is bad and blurry.
Could you please share a screenshots with better resolution?
Tnak you.
After cubenx update and a reboot I can able to do what I need. Verymuch thanks for you support
