When I try to set Pin locking (for example A8 pin) while it is in Reset_state, the application stops and nothing can be done. This isn't normal, it's some kind of bug, is it?
SGera.1
13 REPLIES 13
SGera.1
Second file
Guru
Not sure, it doesn't open for me either. Seems like you have a lot of packages loaded that may be causing issues.
Perhaps @Khouloud OTHMAN​ can help.
Thanks for your interest in my little problem.
SGera.1
Has anyone found a solution to this problem? @Khouloud OTHMAN​ maybe you?
