2022-04-28 4:47 AM
I am able to read the fixed length fname.
But the pointer to the long filename is always 0.
this is how im reading trough the list of files
FRESULT detect_binariesFolder(){
fresult=f_opendir(&dir, "lu");
fresult=f_readdir(&dir, &filinfo);
fresult=f_findfirst(&dir, &filinfo, "lu", "*.bin");//http://elm-chan.org/fsw/ff/doc/findfirst.html
while (fresult == FR_OK && filinfo.fname[0]) { /* Repeat while an item is found */
fresult=f_findnext (&dir, &filinfo);
fresult=f_closedir(&dir);
return fresult;
I tried the three different cubeMx options for long filenames :
None of them works.
My setup:
2022-04-28 5:09 AM
Okay that wasnt so hard, i just needed to find up to date documentation.
(C:\Users\**your user**\STM32Cube\Repository\STM32Cube_FW_F1_V1.8.4\Middlewares\Third_Party\FatFs\doc)
Apparently the pointer needs to be initialiced by you first.
adding this three lines fixes the code:
char lfn[_MAX_LFN + 1];
filinfo.lfname = lfn;
filinfo.lfsize = sizeof lfn;
return fresult;
2022-04-28 5:09 AM
return fresult;
