2022-01-10 12:13 AM
Datasheet indicates DE is supported on all 4 USART interfaces, but attempting to enable it for USART4 in STM32Cube results in an error:
Mode Conflict with
USART4 : Hardware Flow Control (RS485)
Steps to reproduce:
Software in use:
2022-01-10 12:50 AM
Thanks @MJ, for bringing this up.
I can confirm this erroneous warning, however it does not seem to have any effect on the generated code.
/Peter
@Imen DAHMEN Please forward this to the CubeMX/IDE team.
2022-01-10 01:25 AM
Hi @Peter BENSCH ,
Thank you for flagging this for me!
I added @Sara BEN HADJ YAHYA from CubeMX team for review and provide a status update about this issue.
Imen
2022-01-10 02:28 AM
Hello @MJ ,
Thanks for your feedback,
This issue does not effect the generated code but the warning message is not supposed to be shown, with this being said, a Ticket has been submitted internally to solve this issue.
I will keep you posted with the updates.
Thanks @Imen DAHMEN and @Peter BENSCH for pointing this issue to us,
If you issue is solved, please close this post by clicking the "Select as Best" button. This will help other members of the community find this response more quickly :)
Sara.
