2021-02-23 05:10 PM
I am not sure if this should be in github or here. But I encounter erroneous code when I use math operation on Timer Prescaler setting, details are below
Describe the set-up
Describe the bug
TIM6 LL in CubeIDE/MX prescaler cannot use math operation like 170 - 1, (170-1), 170-2, etc.
This is not a problem with ARR.
posted in https://github.com/STMicroelectronics/STM32CubeG4/issues/24
2021-02-23 10:59 PM
Hello @victagayun
Thanks for your feedback, I'll check it then I'll get back to you.
Khouloud
2021-02-24 02:38 AM
You're right, I have reproduced the issue on my side and it will be fixed.
Thank you @victagayun for raising this issue to our attention and we're sorry for any inconvenience this may have caused.
Khouloud
