STM32H735RGV6 maximum external crystal frequency
2022-10-01 2:54 PM
Hello dear,
I will use "STM32H735RGV6" with an external crystal. In the datasheet, it is stated that "External oscillators: 4-50 MHz HSE". However, in CubeIde I cannot assign 50MHz since it is limited to 48MHz.
Could you help with this issue?
RCC
STM32CubeMX
STM32H7 Series
2022-10-02 11:40 AM
Hello @Ersin Kuşçu,
Let me first welcome you to the Community :)
Glad to know you overcame this problem.
It was a limitation with the older versions of STM32CubeMx, and it's fixed after that.
Thank you for your contribution, and please allow me to close this thread by marking your answer as Best.
Imen
Imen
2022-10-01 5:43 PM
I was using one of the previous versions and when I updated CubeIde then the issue has been solved.
2022-10-02 11:40 AM
Hello @Ersin Kuşçu,
Imen
Imen
