2022-04-19 5:34 PM
After setting RCC and Clock configuration as below, if you run the program, it moves to Error_Handler.
ECS-250-10-33B and ECS-327-34B
What is the problem?
2022-04-20 1:42 AM
As you're using SMD crystals, please try "Crystal/Ceramic resonator" instead of "BYPASS clock source".
