STM32F2xx "USE_HAL_xx_REGISTER_CALLBACKS": where to set them in CubeIDE?
‎2020-03-29 10:58 AM
I use CUBEIDE 1.3.0 with MCU Package STM32F2 V1.9.0 for Nucleo F207.
This package generates a file "stm32f2xx_hal_config.h". In this file, all "USE_HAL_***_REGISTER_CALLBACK" defines are set / not set.
What is the proper way to enable these defines? I don't find a switch within the CubeIDE environment. These defines are not in a Begin_user / End-User section. If I enable one, it got overwritten by next time code-generation.
Other CPU types like STM32L4 MCU Packages don't generate these defines, I normally set these as global define with the compiler preprocessor settings.
With F2xx MCU Package, this does not help. The compiler complains about "redefinition" of these defines.
File: stm32f2xx_hal_config.h
#define USE_HAL_SPI_REGISTER_CALLBACKS 0U /* SPI register callback disabled */
#define USE_HAL_TIM_REGISTER_CALLBACKS 0U /* TIM register callback disabled */
#define USE_HAL_UART_REGISTER_CALLBACKS 0U /* UART register callback disabled */
#define USE_HAL_USART_REGISTER_CALLBACKS 0U /* USART register callback disabled */
STM32CubeMX
STM32F2 Series
‎2021-01-28 2:17 AM
‎2020-03-31 9:42 AM
​Hello @Johannes​,
Your reported case will be raised internally to take in consideration.
Imen
‎2020-04-06 4:27 AM
‎2020-04-06 4:31 AM
‎2021-01-28 2:17 AM
Now supported in CubeMX. From the help PDF:
