STM32F2xx "USE_HAL_xx_REGISTER_CALLBACKS": where to set them in CubeIDE?
Johannes
I use CUBEIDE 1.3.0 with MCU Package STM32F2 V1.9.0 for Nucleo F207.
This package generates a file "stm32f2xx_hal_config.h". In this file, all "USE_HAL_***_REGISTER_CALLBACK" defines are set / not set.
What is the proper way to enable these defines? I don't find a switch within the CubeIDE environment. These defines are not in a Begin_user / End-User section. If I enable one, it got overwritten by next time code-generation.
Other CPU types like STM32L4 MCU Packages don't generate these defines, I normally set these as global define with the compiler preprocessor settings.
With F2xx MCU Package, this does not help. The compiler complains about "redefinition" of these defines.
File: stm32f2xx_hal_config.h
#define  USE_HAL_SPI_REGISTER_CALLBACKS         0U /* SPI register callback disabled       */
#define  USE_HAL_TIM_REGISTER_CALLBACKS         0U /* TIM register callback disabled       */
#define  USE_HAL_UART_REGISTER_CALLBACKS        0U /* UART register callback disabled      */
#define  USE_HAL_USART_REGISTER_CALLBACKS       0U /* USART register callback disabled     */
jnewcomb
Now supported in CubeMX. From the help PDF:
4 REPLIES 4
Imen GH
​Hello @Johannes​,
Your reported case will be raised internally to take in consideration.
Imen
Hello jvisser,
Could you please share your ioc file ?
Thanks,
Khouloud
Johannes
See attached file. This file is for STM32F072, happens here as well. (from CUBE_IDE)
Johannes
jnewcomb
