2019-07-16 8:11 AM
How can I have more info about this device? Datasheet, examples and so on..
Why I can't find it on the CubeMX (neither in Keil device list) also installing the F0 v1.0.0 package?
Which device I've to set in Keil?
Thanks in advance,
Antonio
2019-07-16 8:53 AM
As I recall ST changed the part number around 2014
https://community.st.com/s/question/0D50X00009Xkb7MSAR/stm32f050-replacement
http://www.bdtic.com/download/ST/STM32F050x4_STM32F050x6.pdf
2019-07-16 8:53 AM
2019-07-18 12:13 AM
Thank you very much @Community member . With your suggestion, I have found the ST documentation of device name change.
