STM32CubeMX 5.1.0 SAI configuration issue
2019-02-27 5:45 AM
With the new 5.1.0 version of CubeMX, the SAI synchronization seems to be broken.
I'm using a STM32F765VGTx controller.
I have attached my SAI configuration as a screenshot. With CubeMX 5.0.1 this was no problem and the correct code was generated. However, after the update, my configuration is broken and I can't select the "Synchronous Slave" configuration.
Am I doing something wrong or is this broken in the new CubeMX version?
I have the same behavior, when I create a completly new project.
SAI
STM32CubeMX
STM32F7 Series
2019-02-28 5:11 AM
Hello @d.zipperle.5512730769682947E12
Thank you for the feedback, this reported internally for further check.
Best Regards,
Khouloud
2019-03-04 1:01 AM
Hi @d.zipperle.5512730769682947E12
Issue will be fixed in the next CubeMX release.
Thanks and Best Regards,
Khouloud.
2019-03-14 1:03 AM
Same Problem here with STM32F469IIT6 and SAI1 configuration issue.
We can't select the configuration showed in the screenshot.
BUT if we swap the mode setting (SAI B Mode Master), then synchronous slave would be selectable.
We looking forward to the next CubeMX relase.
Thanks in advance.
Lothar
2019-04-06 6:19 AM
Hello Khouloud ,
When it will happen? What is workaround until then?
This post is from February, and this still tot working as expected.
kind regards
Mikolaj Tutak
2019-04-10 12:21 AM
Hi @Nixz
In the next CubeMX release : 5.2.0 version, wich will be available W17 .
Best Regards,
Khouloud.
