STM32Cube Ver 4.26.1 "LWIP_HTTPD_DYNAMIC_HEADERS" setting
New.Fish
I use STM32Cube Ver 4.26.1 to generate LWIP code with HTTPD, it keep print "Assertion "HTTP headers not included in file system" failed at line 2271 in ..\Middlewares\Third_Party\LwIP\src\apps\httpd\httpd.c " .
I find it is in file "httpd_opts.h", " LWIP_HTTPD_DYNAMIC_HEADERS" is not defined.
From Cube ==>Configuration ==>LWIP ==> HTTPD, nowhere can I define " LWIP_HTTPD_DYNAMIC_HEADERS".
Any suggestions?
Nawres GHARBI
Hi @Zhang.Sam
You can activate this define from the LWIP configuration window
Open the configuration window
Switch to HTTPD tab
Enable LWIP_HTTPD
Search for the needed parameter and you will found it (be sure the advanced checkbox is checked)
This refers to the method how the files which are to be served are stored - with or without the headers sent out before the "webpage" itself.
In the "normal" incarnations of lwip there's a utility attached to be used to generate the "filesystem", called makefsdata, that can generate the "filesystem" (fsdata.c) with or without the headers. In the generated fsdata.c, every "file" has a fsdata_file struct which describes that "file", and one of its fields is http_header_included (which, while declared as u8, is in fact a boolean value). The assert above says, that "header for this file is not included, and I don't know how to generate headers dynamically".
Quoting from httpd.c:
 * By default, the server assumes that HTTP headers are already present in
 * each file stored in the file system. By defining LWIP_HTTPD_DYNAMIC_HEADERS in
 * lwipopts.h, this behavior can be changed such that the server inserts the
 * headers automatically based on the extension of the file being served. If
 * this mode is used, be careful to ensure that the file system image used
 * does not already contain the header information.
 * File system images without headers can be created using the makefsfile
 * tool with the -h command line option.
I don't Cube/CubeMX so can't comment on what you can or cannot achieve by wildly clicking.
Nawres GHARBI
Hi @Zhang.Sam
Switch to HTTPD tab
Enable LWIP_HTTPD
