2024-08-05 2:04 AM
I have a DAC signal from an ADC (potentiometer). I have set the frequency from 0-200 Hz but when I run it when I am at 200 and the sign should still be there, the signal on the oscilloscope disappears (just a straight line). does anyone know how to fix it?
2024-08-10 1:24 AM
@meriarajagukguk wrote:I’ve already tried to explain it,
No, you haven't.
You have not explained what your system is actually trying to achieve - as a black box.
