2022-09-21 11:32 AM
Hi ,
I am trying to install CubeMX on MAC M1 . I have been getting this error
Exe path is: /Applications/SetupSTM32CubeMX-6.6.1.app/Contents/MacOs
Search java from relative path ----
Checking java in /Applications/SetupSTM32CubeMX-6.6.1.app/Contents/MacOs/./jre/bin/java
Checking java in /Applications/SetupSTM32CubeMX-6.6.1.app/Contents/MacOs/../jre/bin/java
Checking java in /Applications/SetupSTM32CubeMX-6.6.1.app/Contents/MacOs/../../jre/bin/java
Checking java in /Applications/SetupSTM32CubeMX-6.6.1.app/Contents/MacOs/../../../jre/bin/java
Checking java in /Applications/SetupSTM32CubeMX-6.6.1.app/Contents/MacOs/./jre/Contents/Home/bin/java
Checking java in /Applications/SetupSTM32CubeMX-6.6.1.app/Contents/MacOs/../jre/Contents/Home/bin/java
Checking java in /Applications/SetupSTM32CubeMX-6.6.1.app/Contents/MacOs/../../jre/Contents/Home/bin/java
Checking java in /Applications/SetupSTM32CubeMX-6.6.1.app/Contents/MacOs/../../../jre/Contents/Home/bin/java
Please install Java JDK 11.0.10 or a more recent version
My java echo is printing out this
echo $JAVA_HOME
/Library/Java/JavaVirtualMachines/jdk-19.jdk/Contents/Home
Can anyone pls help me with this
2022-10-05 5:22 PM
I got it resolved. It was just the java package which was missing . Thanks Imen
2022-09-27 5:46 AM
Hello @RDodd.1 ,
Are you installing CubeMX with admin rights?
Make sure you have administrator rights and I advise you to follow the steps described in the UM1781, in the "3 Installing and running STM32CubeMX" section.
Please keep me informed about your progress on this issue.
Imen
2022-10-05 5:22 PM
