MX 5.4.0 Bug: cubemx stuck at copying library files while Generating code
Viraj shah
can anyone help me with this problem cubemx is stuck at copying library file while i try to generate code for keil mdk version 5.28 cannot close the window and have to terminate the program using task manager i am using windows 10 system0690X00000ArJc0QAF.png
33 REPLIES 33
Mikhail Z
Senior II
Did you try to reinstall MX?
Viraj shah
Yes i tried that also previously i was using 5.3 version(the same error persisted there, hence i updated mx to 5.4) deleted that installed 5.4 mx and since it was not working i reinstalled 5.4 but still no luck
LukusD
I'm having the same problem here (STMCubeMX V5.28), program freezes at "Copying library files". Trying to fix this for last 4 hours. I have also tried uninstalling and reinstalling to no avail. I thought it was a problem with Java RTE, so I uninstalled the older version and reinstalled the latest 64 bit. Also no luck. Anyone able to comment or understands what is causing this? Would greatly appreciate any feedback...
Khouloud ZEMMELI
​Hello @Viraj shah​ , could you please share your ioc file ?
Thanks,
Khouloud.
Hi @Khouloud ZEMMELI​  please check the attached .ioc file
​It works fine for me :
oh ok that's interesting ,so can you help me figure out with why this isn't working on my PC?
​Please give me some info about your machine , Win 10 32bit /64bit ? java version?
Hi @Khouloud ZEMMELI​  extremely sorry for replying so late
so i am working on windows 64 bit and java version is 8
