2016-08-10 6:43 AM
Java version 1.8u102.
I can't set project name in project settings, any name will get a alert ''Location cannot be found or created, Please change project location Name''when I use root run it, things seems fine, can you to fix this? #stm32 #!cubemx #cubemx2016-08-11 1:56 AM
Hi Tension,
Could you precise with which MX version you have found the issue. So, we can verify it.-Syrine-
