macOS CubeMX can't set project directory.additional it's icon doesn't display
Microstar
Posted on August 10, 2016 at 15:43
Java version 1.8u102.
I can't set project name in project settings, any name will get a alert ''Location cannot be found or created, Please change project location Name''
when I use root run it, things seems fine, can you to fix this?
#stm32 #!cubemx #cubemx
1 REPLY 1
Nesrine M_O
Lead II
Posted on August 11, 2016 at 10:56
Hi Tension,
Could you precise with which MX version you have found the issue. So, we can verify it.
-Syrine-
