2024-06-23 1:45 PM
6.11.1 with STM32U575RITx
when I click "CMSIS RTOS2" to enable the installed middleware X-CUBE-FREERTOS, mouse shows a busy icon and the FreeRTOS configuration in the bottom panel never opens.
STM32CubeIDE can open the IOC file and the FreeRTOS configuration panel is displayed there fine.
2024-06-23 22:29:08,573 [INFO] ThirdParty:1030 - CMSIS Pack Vendor :STMicroelectronics X-CUBE-TOF1 3.0.0
2024-06-23 22:29:08,574 [INFO] ThirdPartyModel:298 - Start build external matchings
2024-06-23 22:29:10,742 [INFO] ThirdPartyModel:316 - End build external matchings
2024-06-23 22:29:10,778 [INFO] LoadServerUpdatesThread:375 - End of LoadServerUpdate Thread
Jun 23, 2024 10:29:38 PM java.util.prefs.FileSystemPreferences checkLockFile0ErrorCode
WARNING: Could not lock System prefs. Unix error code 2.
Jun 23, 2024 10:29:38 PM java.util.prefs.FileSystemPreferences syncWorld
WARNING: Couldn't flush system prefs: java.util.prefs.BackingStoreException: Couldn't get file lock.
2024-06-23 22:30:08,141 [INFO] RtosManager:919 - Current active RTOS is STMicroelectronics.X-CUBE-FREERTOS.1.2.0 [CortexM33]
Jun 23, 2024 10:30:08 PM java.util.prefs.FileSystemPreferences checkLockFile0ErrorCode
Jun 23, 2024 10:30:08 PM java.util.prefs.FileSystemPreferences syncWorld
Exception in thread "AWT-EventQueue-0" java.lang.NoSuchMethodError: 'void sun.misc.Unsafe.ensureClassInitialized(java.lang.Class)'
at com.oracle.truffle.api.library.LibraryFactory.ensureLibraryInitialized(LibraryFactory.java:384)
at com.oracle.truffle.api.library.LibraryFactory.getUncached(LibraryFactory.java:364)
at com.oracle.truffle.api.library.LibraryFactory.<init>(LibraryFactory.java:210)
at com.oracle.truffle.api.interop.InteropLibraryGen.<init>(InteropLibraryGen.java:178)
at com.oracle.truffle.api.interop.InteropLibraryGen.<clinit>(InteropLibraryGen.java:169)
at java.base/java.lang.Class.forName0(Native Method)
at java.base/java.lang.Class.forName(Class.java:529)
at java.base/java.lang.Class.forName(Class.java:508)
at com.oracle.truffle.api.library.LibraryFactory.loadGeneratedClass(LibraryFactory.java:791)
at com.oracle.truffle.api.library.LibraryFactory.resolveImpl(LibraryFactory.java:740)
at com.oracle.truffle.api.library.LibraryFactory.resolve(LibraryFactory.java:733)
at com.oracle.truffle.api.interop.InteropLibrary.<clinit>(InteropLibrary.java:2941)
at com.oracle.truffle.polyglot.PolyglotValueDispatch.<clinit>(PolyglotValueDispatch.java:170)
at com.oracle.truffle.polyglot.PolyglotImpl.initialize(PolyglotImpl.java:166)
at org.graalvm.polyglot.impl.AbstractPolyglotImpl.setConstructors(AbstractPolyglotImpl.java:288)
at org.graalvm.polyglot.Engine$1.loadAndValidateProviders(Engine.java:1107)
at org.graalvm.polyglot.Engine$1.run(Engine.java:1067)
at org.graalvm.polyglot.Engine$1.run(Engine.java:1061)
at java.base/java.security.AccessController.doPrivileged(AccessController.java:319)
at org.graalvm.polyglot.Engine.initEngineImpl(Engine.java:1061)
at org.graalvm.polyglot.Engine$ImplHolder.<clinit>(Engine.java:143)
at org.graalvm.polyglot.Engine.getImpl(Engine.java:367)
at org.graalvm.polyglot.Engine$Builder.build(Engine.java:665)
at com.st.microxplorer.mcu.rtos.data.RtosDataEditor.<init>(RtosDataEditor.java:365)
at com.st.microxplorer.mcu.rtos.data.RtosDataPanel.createDefaultTask(RtosDataPanel.java:289)
at com.st.microxplorer.mcu.rtos.data.RtosDataPanel.<init>(RtosDataPanel.java:151)
at com.st.microxplorer.mcu.rtos.data.RtosDataGroupPanel.<init>(RtosDataGroupPanel.java:39)
at com.st.microxplorer.mcu.rtos.data.RtosUserConfigurationPanelBuilder.getConfigurationPanels(RtosUserConfigurationPanelBuilder.java:55)
at com.st.microxplorer.mcu.rtos.data.RtosUserConfigurationPanelBuilder.getRtosConfigurationPanel(RtosUserConfigurationPanelBuilder.java:122)
at com.st.microxplorer.plugins.ipmanager.generictreatment.gui.MainPanel.buildSharedComponentTabs(MainPanel.java:429)
at com.st.microxplorer.plugins.ipmanager.generictreatment.gui.MainPanel.createTabs(MainPanel.java:387)
at com.st.microxplorer.plugins.ipmanager.generictreatment.gui.MainPanel.<init>(MainPanel.java:164)
at com.st.microxplorer.plugins.ip.genericplugin.GenericPlugin.getUI(GenericPlugin.java:48)
at com.st.microxplorer.plugins.ipmanager.gui.BlockDiagram.createIpPanel(BlockDiagram.java:422)
at com.st.microxplorer.plugins.ipmanager.gui.BlockDiagram.getIPConfigPanel(BlockDiagram.java:560)
at com.st.microxplorer.plugins.ipmanager.gui.BlockDiagram.getIPConfigPanel(BlockDiagram.java:466)
at com.st.microxplorer.plugins.ipmanager.gui.BlockDiagram.propertyChange(BlockDiagram.java:1311)
at java.desktop/java.beans.PropertyChangeSupport.fire(PropertyChangeSupport.java:343)
at java.desktop/java.beans.PropertyChangeSupport.firePropertyChange(PropertyChangeSupport.java:335)
at com.st.microxplorer.mxsystem.MxSystem.propertyChange(MxSystem.java:474)
at java.desktop/java.beans.PropertyChangeSupport.firePropertyChange(PropertyChangeSupport.java:268)
at com.st.microxplorer.util.MXPropertyChangeSupport.firePropertyChange(MXPropertyChangeSupport.java:54)
at com.st.microxplorer.mcu.Mcu.propertyChange(Mcu.java:1803)
at com.st.microxplorer.mcu.Mode.firePropertyChange(Mode.java:2208)
at com.st.microxplorer.mcu.Mode.setMode(Mode.java:1935)
at com.st.microxplorer.peripheralpanel.CheckSwPackMode.doAction(SwPackMode.java:910)
at com.st.microxplorer.peripheralpanel.CheckSwPackMode$1.run(SwPackMode.java:894)
at java.desktop/java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:318)
at java.desktop/java.awt.EventQueue.dispatchEventImpl(EventQueue.java:773)
at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:720)
at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:714)
at java.base/java.security.AccessController.doPrivileged(AccessController.java:400)
at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:87)
at java.desktop/java.awt.EventQueue.dispatchEvent(EventQueue.java:742)
at java.desktop/java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:203)
at java.desktop/java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:124)
at java.desktop/java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:113)
at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:109)
at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.desktop/java.awt.EventDispatchThread.run(EventDispatchThread.java:90)
2024-06-23 22:30:08,606 [WARN] IP:2120 - rccPrivilegeSecure not found: check if there is a RefParameter without a condition.
2024-06-23 22:30:08,607 [WARN] IP:2120 - rccSecurity not found: check if there is a RefParameter without a condition.
2024-06-23 22:30:08,683 [WARN] IP:2120 - rccPrivilegeSecure not found: check if there is a RefParameter without a condition.
2024-06-23 22:30:08,683 [WARN] IP:2120 - rccSecurity not found: check if there is a RefParameter without a condition.
Jun 23, 2024 10:30:38 PM java.util.prefs.FileSystemPreferences checkLockFile0ErrorCode
2024-06-25 1:45 PM - edited 2024-06-25 1:45 PM
I think opening the IOC file in STM32 Cube IDE fixed the problem, somehow.
The RTOS tab now works normally in Cube MX.
also yes everything is installed.
2024-06-24 8:08 AM
Hi @grumblyturtle ,
Before Selecting the FreeRTOS™ version and heap model at CMSIS RTOS2, make sure that X-CUBE-FreeRTOS is added properly.
You need to:
Try this way and let me know if you still have the java issue or not.
-Amel
2024-06-24 8:24 AM
Thanks for the reply, obviously the module is installed, otherwise I would not even see the checkbox to enable it.
Clicking the CMSIS RTOS2 checkbox produces the described freeze and errors in the log.
2024-06-24 9:00 AM
What About the Heap? Make sure that required selections are done:
-Amel
2024-06-26 1:24 AM
Glad to know that your problem is fixed. Have a nice day @grumblyturtle.
