Is it possible to configure Software interrupts in QubeMX?
MGeri.1
We rely on QubeMX to generate our boilerplate and initialization code as much as possible. Currently we configure a Software interrupt programatically via
HAL_EXTI_SetConfigLine(...);
HAL_NVIC_SetPriority(...);
HAL_EXTI_RegisterCallback(...);
HAL_NVIC_EnableIRQ(...);
And later we invoke the code via
HAL_EXTI_GenerateSWI(...);
This is finde and it works. However I'm curious if this can be assisted by CubeMX? I see there are EXTI lines available in the NVIC section, but I can't enable them.
3 REPLIES 3
Hello @MGeri.1​ ,
Yes, it is possible to configure the interrupts by CubeMX.
Take a look at this video, it might help you.
BeST Regards,
Walid
MGeri.1
Hi @Walid ZRELLI​
thank you for the video. Unfortunaltely this only covers External Interrupts triggered by GPIO. What I want to achieve is to configure a Software Interrupt, that does not need a GPIO pin.
Hello @MGeri.1​ ,
Unfortunately, you have to configure the software interrupts manually. It is not supported by CubeMX.
BeST Regards,
Walid
