I2S master transfer signal is something wrong
Tank2005
My environment is Nucleo-F446RE with STM32CubeMX 5.1 / TrueSTUDIO 9.3.
I created an I2S master transmit test program. [Full project archive is
here]
  • Transmission Mode / Mode Master Transmit
  • Communication Standard / LSB First(Right Justified)
  • Data and Frame Format / 16 Bits Data on 16 Bits Frame
  • Selected Audio Frequency / 48KHz(*I2S cloks is 61.44(8MHz /5 * 192 /5)MHz)
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
#define I2S_CODE 0b1010110011110000
#define I2S_BUFFER_SIZE 64
#define I2S_BUFFER_HALF_SIZE (I2S_BUFFER_SIZE / 2)
uint16_t buffer[I2S_BUFFER_SIZE];
void HAL_I2S_TxHalfCpltCallback(I2S_HandleTypeDef *hi2s)
	uint16_t *sp = buffer;
	for(int i = 0; i < I2S_BUFFER_HALF_SIZE; i++) *(sp++) = I2S_CODE;
void HAL_I2S_TxCpltCallback(I2S_HandleTypeDef *hi2s)
	uint16_t *sp = buffer + I2S_BUFFER_HALF_SIZE;
	for(int i = 0; i < I2S_BUFFER_HALF_SIZE; i++) *(sp++) = 0x00;
void StartI2STransfer()
  memset (buffer, 0, sizeof(buffer));
  HAL_I2S_Transmit_DMA(&hi2s2, buffer, I2S_BUFFER_SIZE * sizeof(uint16_t));
/* USER CODE END 0 */
int main(void)
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  StartI2STransfer();
  while (1)
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
However, STM32F4 outputs a same signal twice.
For example, in this program, I put the I2S signal as "10101100111100001010110011110000...". But a output signal is "10101100101011001111000011110000..." like this image.
Please tell me how to solve this problem.
Piranha
Chief II
  1. In DMA configuration You have peripheral and memory data sizes set to byte, but with 16-bit data both of them should be half-word.
  2. HAL_I2S_Transmit_DMA function's 3rd parameter is data item count (total for both channels) not byte count.
Piranha
Chief II
After changing a parameter to "Half Word", that signal was output as I expected. Thank you so much.
