2020-05-11 9:49 AM
EDIT:
I installed STM32CubeMX 5.6.1. When I ran CubeMX it freezes when I click Install/Remove embedded software packages. How can I fix that?
There is a section for managing software installation. When I click any button here ("CHECK FOR UPDATES" or "INSTALL / REMOVE") the CubeMX freezes completely
2020-05-11 1:59 PM
Hello @Ayaz Agayev
Try to check your Network connection.
Then click on Refresh before Install embedded software packages.
Best regards,
Nesrine
2020-05-11 11:42 PM
Hello, I was solved the issue, I switched from openjdk 8 to oraclejdk 14 and problem solved. By the way I'm using Ubuntu 20.04
