2024-05-05 7:34 PM
I have question. Unable to download STM32CubeMX, any solutions? thanks :)
2024-05-05 10:16 PM
Hello @northam
Quite a common problem for new-comers.
To download CubeMX, you need to download Java Runtime. It's of a necessity.
If separate download can't fix your problem, you should download one of the earliest versions of CubeMX and check for updates inside it.
Why? Because in earlier versions, the java runtime is included. In this way you can have a smooth access to CubeMX.
If this answers to your question, it would be nice of you to click on "Accept as solution".
Good luck.
Nathan Xi
2024-05-05 11:58 PM
@northam Unfortunately your statements are not correct:
However, we are currently working on fixing the download problems that sometimes occur under specific circumstances.
/Peter
2024-05-08 3:35 PM
Hello @northam.,
This post has been escalated to the ST Online Support Team for additional assistance.
Should anyone else have a similar question about download issues, please submit your request directly to the ST Online Support Team at https://my.st.com/ols
Regards,
Roger
