2021-07-13 9:22 AM
Is there an export/import option for pin configuration?
2021-07-13 10:50 AM
Hello @JKlec ,
I recommend you to refer to this UM1718 for easy exporting of current configuration to a compatible MCU.
You can follow the instruction in the section "Tutorial 5: Exporting current project configuration to a compatible MCU".
Hope my answer helped you!
When your question is answered, please close this topic by choosing Select as Best.
Imen
2021-07-13 10:50 AM
Hello @JKlec ,
Imen
2021-07-13 11:15 AM
Thank you very much.
***Edited by moderation*** - please do not share personal data in public posts
