I am using Winbond's Quad SPI NOR Flash memory (W25Q128JW). Which of Micron or Macronix should be selected for the memory_type of the OCTSPI setting parameter of cubeMX?
Options
2022-02-10 5:27 PM
Options
2022-02-10 5:59 PM
I'm not using CubeMX, but as I recall I used Micron mode when I was testing the Winbond parts on the H7 OCTOSPI parts.
Easy enough to change in the HAL structures.
1 REPLY 1
Options
2022-02-10 5:59 PM
