I am using Winbond's Quad SPI NOR Flash memory (W25Q128JW). Which of Micron or Macronix should be selected for the memory_type of the OCTSPI setting parameter of cubeMX?
YNaka.6
I'm not using CubeMX, but as I recall I used Micron mode when I was testing the Winbond parts​ on the H7 OCTOSPI parts.
Easy enough to change in the HAL structures.​
1 REPLY 1
