2018-09-20 04:44 AM
Hi. Can you help me to get last version cube mx under Windows XP.
Thank you.
2018-09-20 05:35 AM
Which version would that be? Wouldn't it be limited by the installable version of Java?
It's 2018, time to get a system with a currently supported OS
2018-09-20 05:35 AM
2018-09-20 08:39 AM
As recommended by Clive, it will be better to update and use supported OS (Windows® 7, Windows® 8 or Windows® 10) as mentioned in the UM1718.
You can download the last version of STM32CubeMX tool from ST web page:
Please follow the instructions and requirements in the User Manual UM1718 to install and use STM32CubeMx tool.
Kind Regards,
Imen.
2018-09-20 08:44 AM
Consider Linux if you have no budget.
