How can I activate EXTI interruptions that are blocked with Enable?
‎2022-03-02 8:54 PM
‎2022-03-03 8:56 AM
As @TDK​ mentioned: hovering the disabled box shows The corresponding GPIO pin is left as "Free" and ....
So you need to assign the pin context to the Cortex-M7. To do that:
- open the peripheral GPIO, e.g. using the categories A->Z on the left side
- select the GPIO in question (in your case PC13)
- in the configuration change Pin Context Assignment from Free to ARM Cortex-M7 (NVIC1 relates to C-M7)
- then either:
- select tab NVIC (same page in configuration of GPIO) and tick the box at EXTI line[15:10] or
- open the peripheral NVIC1 and tick the box at EXTI line[15:10] there
Does it answer your question?
/Peter
‎2022-03-02 11:33 PM
Simply tick the relevant box on EXTI Line, in this case EXTI Line [15:10]. A corresponding interrupt function is then generated by CubeMX or the CubeIDE.
You can read about the respective EXTI lines in the reference manual for the respective STM32 family.
/Peter
‎2022-03-03 12:10 AM
I clicked on the box, but I couldn't activate it.
Can you see that the color is different from the other boxes?
I don't know why it is like this.
‎2022-03-03 6:03 AM
There's probably a reason it's disabled. Hover over it and see if a note pops up. If that's not it, attach the IOC.
‎2022-03-03 6:45 AM
Disclaimer: I have no direct experience with dual-core STM32 CPUs, but... Do you need to map that EXTI pin to one of the cores first?
‎2022-03-03 8:56 AM
- then either:
/Peter
‎2022-03-03 5:45 PM
I saw a popup hover over it
that talk "The corresponding GPIO pin is left as "Free" and not used by any middleware or pack."
Thanks to you, I was able to solve the problem.
‎2022-03-03 5:46 PM
I solved the problem by following your instructions.
Thank you for your kindness.
