Hello, Today i updated to STM32CubeIDE 1.8.0 However when i tried to create a project based on a B-L4S5I-IOT01A Board i get an error saying
‎2022-02-09 10:48 AM
"Error downloading files: stm32cube_fw_14_v1170.zip (cannot unzipped) and stm32cube_fw_14_v1171.zip (Dependency no loaded).
I also tried to update my Firmware using the Help updates links:
Check for Embedded package software updates...but i receive the exact same error as i cited above.
Can you please tell me what the problem is and how to fix it ?
Thanks Dr Barry H
- Labels:
STM32CubeIDE
STM32CubeMX
STM32L4 series
‎2022-02-10 4:55 AM
You can do:
Help > Manage Embedded Software Package > Refresh
Then, you look at STM32L4 and try to install the latest version.
‎2022-02-09 11:54 PM
Hi @BHend.1​ ,
Can you please delete:
1/ stm32cube_fw_L4_v1170.zip and STM32Cube_FW_L4_V1.17.0 [if exist]
2/ All TMP_*** folder in your repository
3/ Do a Refresh
4/ Install again STM32Cube_FW_L4_V1.17.1
Let me know your result.
Regards,
Aymen.
‎2022-02-10 4:20 AM
Hi Aymen,
Thanks for the information. But first of all where do i find my STM32CubeIDE Repository ?
When i start up the application i see my current workspace ......but i am not sure where my repository is on my hard drive ?
I am using a Windows 10 machine.
Thanks, Dr Barry
‎2022-02-10 4:36 AM
Hi @BHend.1​ ,
The repository is under:
C:\Users\<User_Name>\STM32Cube\Repository
Regards,
Aymen.
‎2022-02-10 4:38 AM
Hi Ayman,
For my windows machine i have installed the STM32CubeIDE software in this location:
E:\ST\STM32CubeIDE_1.8.0\STM32CubeIDE\
But where would i find the Repository ?
Thanks, Dr Barry
‎2022-02-10 4:48 AM
Hi Ayman, Ok thanks for the info. I found my repo. I deleted the files you mentioned. I started up STM32CubeIDE again..... when you say "do a refresh" How do i do that ?
How do i install STM32Cube_FW_L4_V1.17.1 ?>
Do i achieve the result by : Help -> Check for updates ... and / or help-> Install new Software ?
I want to get it right so that my setup is correct this time.
Thanks for the help,
Dr Barry
‎2022-02-10 4:55 AM
You can do:
‎2022-02-10 5:23 AM
Hi Aymen, Brilliant ! Thanks very much for the help. After doing a Refresh and then installing the latest package for STM32L4 i can now create a new project.
Best regards, Dr Barry
‎2022-02-10 5:25 AM
Good news, can you please make my last comment as 'Best answer' ?
Thank you in advance.
‎2022-02-10 5:28 AM
Hi Aymen, Yes i just liked your answers and made the last one "Select as Best". That was what i call very good real time support . Great, thank again for your help :)
