Hello I'm started a project with STM32G474 MCU and STM32 Cube MX + IDE. I've added FreeRTOS and keep all options to default settings. My project freeze when timer interrupt is enabled but the default interrupt handle is not called. Anyone has a idea ?
SDela.1
1 REPLY 1
Probably a code bug. Debug the code, hit pause, see where the CPU is at and go from there.
