Generated uVision Project File is corrupted
‎2025-03-07 2:26 AM
When generating code in CubeMX for the MDK-ARM Toolchain, the uVision Project file (.uvprojx) is corrupted.
When I try to open the project it shows the following message:
Comparing the project files shows that the following section gets removed:
Manually adding this section back solves the problem temporarily until the next code generation is done.
What could be the cause for this?
I´ve already tried different versions of STM32CubeMX and uVision.
Current Versions: CubeMX: 6.14.0
uVision: 5.41
STM32U585 V 1.7.0
STM32CubeMX
STM32U5 series
‎2025-03-13 4:49 AM
I could fix it by deleting the uVision Project File and regenerate it by CubeMX
‎2025-03-07 3:14 AM
Hello @Jonas3
First et me thank you for posting.
I am not able to reproduce the exact behavior. I would need the ioc file which is causing you the error to test with it.
KR,
Semer.
‎2025-03-13 4:49 AM
