Generate Report via command line
‎2023-11-20 2:13 AM
Hello everyone.
Is there a way to generate the report files (pdf and txt) via command line in CubeMX?
I run STM32CubeMX in command-line mode getting commands from a script,but I didn't find any commands about report generation in the command line summary table.
Greetings
STM32CubeMX
‎2023-11-20 6:46 AM - edited ‎2023-11-20 6:46 AM
Hello @nickf,
Let me thank you for posting and welcome to the ST community.
It is not possible to generate a report via command line. For more information about the STM32CubeMx command line, I suggest that you consult the UM1718 section 3.3.2.
Thanks.
Mahmoud
Hello @nickf,
Thanks.
Mahmoud
