2024-03-13 09:52 AM
When i configure a project with CubeMX and TouchGFX Generator stuff and save this,
after a new start of CubeMX and opening the .ioc file again i get this error message:
And my TouchGFX Generator Configuration is lost. The other configuration is still there.
Now, under "Software Packs Component Selector" the Generator Application is "Not selected" although i selected the Generator Application in the previous session:
After selecting the Generator and Clicking OK button, the TouchGFX Generator is back, but not what i have configured there in the previous session.
Does someone know why this happens?
I use:
Debian Linux 11.9
CubeMX 6.10.0
X-CUBE-TOUCHGFX 4.23.0
Thank you.
2024-03-27 12:32 PM
Hello @sk-st ,
Please follow the steps that I have described in this post to download and install the X-CUBE-TouchGFX manually into STM32CubeMX.
2024-03-16 12:06 PM
2024-03-27 12:32 PM
Hello @sk-st ,
2024-04-02 01:27 AM
Hello Imen,
thank you for your help.
The problem does no longer occur.
