CubeMX support for Cmake
yourigh
I would like to use the offical VScode extentention together eith STM32CubeMX.
The guide says I need to set up MX generator Toolchain / IDE to Cmake.
However I have no such option:
How could I use the extention with CubeMX?
I remember the option was there about a year ago on a different MCU (F3).
I have STM32F103C8.
Thank you!
Imen.D
Hi @yourigh ,
Try with the latest release (Version 6.11.0)
Imen
6 REPLIES 6
AScha.3
Chief III
if you choose : makefile ...?
Imen.D
Hello @yourigh,
Please try with latest release of STM32CubeMx (V 6.11.0).
AN5952 This application note describes how to use CMake in STM32CubeIDE.
Imen
unfortunately, this does not work then in VScode. It would be possible but it would require a manual setup without the extension.
Thanks for the reply,
I do have exactly that version, under Windows. But I don't have the last option there. Do you have any recommendation what I can do?
Imen.D
Hi @yourigh ,
Imen
Thank you, it works.
I updated the Cube, but it did not go through because of the rights error, so I thought I have the latest one. After the successful update, it started to work.
