CubeMX, missing device-setting in generated EWARM project
‎2016-07-12 7:05 PM
Hi, I encountered following.
When I set device type as ''ST STM32F401xE'' on EWARM, the project was build successfully. Is the device type should determined everytime? with, STM32CubeMX Version 4.15.1 STM32Cube FW_F4 V1.12.0 procedure,by CubeMX
File -> NewProject Board Selector -> MCU Series -> STM32F4 -> NUCLEO-F401RE Nothing changeProject -> Settings -> Projcet Name:f401_projectname
Toolchain / IDE -> EWARM OK Generate CodeOpen Project(IAR Embedded Workbench ofr ARM 7.10.3.6932, with 32KB code size limitation)
Alt+F7(see option) -> device is set as 'None'.Sice MPU type is not set, EWARM says as following at comilation.
Error[Ta097]:Cannot call intrinsic function ''_nounwind _DSB'' from Thumb mode in this architecture Error[438]:This instruction is not available in the selected cpu/core Error[Ta097]:Cannot call intrinsic function ''_nounwind _RBIT'' from Thumb mode in this architecture Error[Ta097]:Cannot call intrinsic function ''_nounwind _CLZ'' from Thumb mode in this architecture . . . #cubemxSolved! Go to Solution.
- Labels:
STM32CubeMX
‎2016-07-18 8:12 AM
I have just installed IAR 7.60.2 and don't face any more the issue. So I suggest you to install a new IAR version.Regards
‎2016-07-13 1:52 AM
I have the same problem for ''NUCLEO-F401RE'' device when I generate my project with EWARM.Regards- Mark as New
‎2016-07-18 8:12 AM
‎2016-07-21 4:29 PM
I tried using IAR 7.70.1 today, now OK.
Thank you.
