2020-02-12 3:25 AM
Hi, I suppose that the STM32CubeMX V 5.5.0 has a bug for AHB1,2 Peripheral Clocks configuration for the STM32H7A/7B microcontroller.
If you try to configure the AHB1,2 clock to 280MHZ. It indicate a Clock Configuration error: "AHB1,2 Clock Frequency must be =< 140MHZ".
Is it a bug of the CubeMX or the AHB1,2 clock really must be =< 140MHZ?
2020-02-17 5:12 AM
Hello @Community member
Thanks for the feedback, issue fixed, the fix will be available in the next CubeMX Release.
Best Regards,
Khouloud
2020-02-17 5:12 AM
Best Regards,
Khouloud
