CubeMX FreeRTOS Task Template Missing osThreadTerminate (vTaskDelete) Safety Guard
baturarslan
I noticed that the FreeRTOS task function template generated by CubeMX lacks a defensive programming practice recommended in FreeRTOS examples and documentation.
Current Generated Code:
void TaskFunction(void const * argument)
    for(;;)
        // Task code
Recommended Pattern (from FreeRTOS examples):
   for(;;)
       // Task code
   osThreadTerminate(taskTaskHandle); // Safety guard if loop is ever broken
Rationale:
1. While the infinite loop means the code after it should never be reached, having osThreadTerminate(threadID) (vTaskDelete()) acts as a safety guard
2. If the loop is unexpectedly broken (due to a bug or other condition), the current implementation could lead to undefined behavior
3. This pattern is shown and recommended in official FreeRTOS examples and documentation
4. Adding this guard aligns with defensive programming practices
Impact:
- Low: This is not a functional bug as the code works correctly under normal conditions
- Medium priority as it's a best practice improvement for safety
Request:
Could the task function template be updated to include this safety guard in future CubeMX releases?
SofLit
Hello @baturarslan and welcome to the community,
Will escalate this proposal internally for study.
Thank you for your suggestion.
PS: This is NOT an online support (https://ols.st.com) but a collaborative space. So please be polite in your reply. Otherwise, it will be reported as inappropriate and you will be permanently blacklisted from my help/support.
1 REPLY 1
SofLit
