Error in the Stm32CudeIde program
When generating code, the Code Ide generates the following code:
* Name: cmsis_os2.c
* Purpose: CMSIS RTOS2 wrapper for FreeRTOS
osStatus_t osThreadTerminate (osThreadId_t thread_id) {
TaskHandle_t hTask = (TaskHandle_t)thread_id;
osStatus_t stat;
#ifndef USE_FreeRTOS_HEAP_1
eTaskState tstate;
if (IS_IRQ()) {
stat = osErrorISR;
else if (hTask == NULL) {
stat = osErrorParameter;
else {
tstate = eTaskGetState (hTask);
if (tstate != eDeleted) {
stat = osOK;
vTaskDelete (hTask);
} else {
stat = osErrorResource;
#else
stat = osError;
#endif
return (stat);
I have not defined USE_FreeRTOS_HEAP_1. Why is the 'hTask' variable in the code?
The compiler throws an error (or a warning, depending on the settings)
../Middlewares/Third_Party/FreeRTOS/Source/CMSIS_RTOS_V2/cmsis_os2.c:658:16: error: unused variable 'hTask' [-Werror=unused-variable]
Why do you declare if you don't use it? The code should be like this:
osStatus_t stat;
eTaskState tstate;
if (IS_IRQ()) {
stat = osErrorISR;
else {
stat = osOK;
} else {
#else
stat = osError;
#endif
return (stat);
After each code generation, I have to fix several such places. How to fix it?
Where does the generator get the code from? Maybe there is a template in the IDE that can be corrected and there will be no error?
