CubeMX code generation
yuri CH
​Hi!
i have been using cubemx for a while now, and now i am wondering regarding the code generation. in the main file , for example ,there are user code sections. can i create more of theses sections? or must i use the generated sections only?
1 REPLY 1
Khouloud ZEMMELI
Hello @yuri CH​
To ensure that your code will not disappear after each generation of code, you can only put it in the user sections, otherwise, it's not possible to add any code outside these generated sections.
Best Regards,
Khouloud
