2017-02-08 04:09 AM
Hi
in CUBEMX for a L476XX I would like to set up a PWM channel. In the pinout tab of cube under TIM1 I can choose between 'PWM generation ch1' and 'PWM generation ch1N'.
So is it like it just switches the pin for channel 1?
What does ch1N stand for?
In which document would I find the description?
THX
#cubemx-4.19 #timer2017-02-08 04:42 AM
Hello
dieter.dieter
,You should refer to the reference manual
related to your device STM32L476xx (inAdvanced-control timers (TIM1/TIM8) section )and this toreview the pins description and identify the free/usable pins assignment in your configuration.Regards
Imen
