CubeMX 4.21 - Java SE RE 8.0.131 crashing when saving new project
‎2017-05-19 5:34 AM
As in title, when trying to save a new project the Cube crashes generating a Java error log file.
Seems to happen just before opening a file dialogue window to ask where to save the new project.
#cube-mx #stm32cubemx-java #java-crashSolved! Go to Solution.
- Labels:
STM32CubeMX
‎2017-07-15 6:28 AM
Try this
Remove Windows 10 'GodMode shortcut'
Thanks to:
https://stackoverflow.com/questions/43836174/java-applications-crash-when-browse-control-used
After erase, it work's
RDE
‎2017-05-19 6:08 AM
Hi
Pikoulis.George
,Your issue is reported internally and under investigation.
Imen
Imen
‎2017-05-19 8:20 AM
Hi Imen,
Thanks for looking into it. Please keep me posted.
‎2017-05-19 9:10 AM
Imen,
Can't CubeMX (and other Java-based ST programs) come also in an alternative flavour with the JVM bundled? That would create a standalone executable independent of Java being installed on a given machine, and possibly avoid incompatibility issues such as the one reported here.
Jan
‎2017-05-22 2:54 AM
Continuing to the original problem, I've clean installed Java and Cube, after removing all previous installations. Now I'm getting the following error. I guess a bundled version might help, as Jan noted.
''java -version'' runs normally on the command prompt, so Java and its environmental variables should be correct.
‎2017-05-22 7:41 AM
Fixed that error and now I'm still getting the older error (the same as the one generating the log file).
‎2017-05-22 7:51 AM
With Windows and the Registry, things became confusing. Uninstallers often fail to remove all remains of the application's trash from the registry, and reliably prevent a successful re-installation.
You can check out one of those various 'Registry cleaners', or try it on a clean machine.
Having a virtual machine for such purposes proved to be a good idea as well.
‎2017-05-22 7:56 AM
To be honest that's what I did today.
I've made an Ubuntu VM solely for Cube, and it's working pretty well.
‎2017-05-22 8:16 AM
That is kind of a different animal.
Unix/Linux uses a different approach to application configuration, and installation/de-installation.
In fact, the Unix community usually references the Windows Registry as 'a perfect example of a single-point-of-fail'.
They have other issues, though (think OpenJDK vs. Oracle JDK).
I guess a Windows VM would have worked equally well - until tainted ...
‎2017-05-23 12:23 AM
Concerning Win, didn't want to run into licensing problems.
In any case, my Cube projects are just a snapshot away if something bad happens, which makes me sleep easier. I should probably do the same with the compilers.
