CAN Interrupt is not generating, I have Choosed STM32F413ZHTx Nucleo Board, always getting CAN Bus Errors, Even it is not entering Interrupt In that board CAN Transciever is also not there, I have used externally.. thanks in advance..:)
RJANA.2
SofLit
You have to check the following:
  • Can bus connections: STM32F413ZHTx Nucleo Board + your external transceiver that are connected to another CAN node through CAN bus.
  • If you are using CAN in normal mode, HSI clock is not recommended for CAN communications. Please use external precise crystal.
  • Did you tried first to use loopback mode before going to normal mode? This to discard all issues related to your HW. Please refer to the example provided in STM32F4 Cube under the path: \Projects\STM324x9I_EVAL\Examples\CAN\CAN_LoopBack
STM32
PS:
1 - This is NOT an online support (https://ols.st.com) but a collaborative space.
2 - Please be polite in your reply. Otherwise, it will be reported as inappropriate and you will be permanently blacklisted from my help.
2 REPLIES 2
SofLit
STM32
PS:
SofLit
Please also refer to this thread it may help you.
PS:
