Shrikant Patel_2
Mar 12, 2020 12:51 PM UTC
ADC read error after updating to new version of cubemx 5.6
Hi I am using below configuration to read adc channels but I get some good values and some very bad values.
My configurations are :
void MX_ADC1_Init(void)
 /* USER CODE BEGIN ADC1_Init 0 */
 /* USER CODE END ADC1_Init 0 */
 ADC_MultiModeTypeDef multimode = {0};
 ADC_ChannelConfTypeDef sConfig = {0};
 /* USER CODE BEGIN ADC1_Init 1 */
 /* USER CODE END ADC1_Init 1 */
 /** Common config
 hadc1.Instance = ADC1;
 hadc1.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV8;
 hadc1.Init.Resolution = ADC_RESOLUTION_12B;
 hadc1.Init.ScanConvMode = ADC_SCAN_DISABLE;
 hadc1.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
 hadc1.Init.LowPowerAutoWait = DISABLE;
 hadc1.Init.ContinuousConvMode = DISABLE;
 hadc1.Init.NbrOfConversion = 1;
 hadc1.Init.DiscontinuousConvMode = DISABLE;
 hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
 hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
 hadc1.Init.ConversionDataManagement = ADC_CONVERSIONDATA_DR;
 hadc1.Init.Overrun = ADC_OVR_DATA_OVERWRITTEN;
 hadc1.Init.LeftBitShift = ADC_LEFTBITSHIFT_NONE;
 hadc1.Init.OversamplingMode = DISABLE;
 if (HAL_ADC_Init(&hadc1) != HAL_OK)
  Error_Handler();
 /** Configure the ADC multi-mode
 multimode.Mode = ADC_MODE_INDEPENDENT;
 if (HAL_ADCEx_MultiModeConfigChannel(&hadc1, &multimode) != HAL_OK)
  Error_Handler();
 /** Configure Regular Channel
 sConfig.Channel = ADC_CHANNEL_3;
 sConfig.Rank = ADC_REGULAR_RANK_1;
 sConfig.SamplingTime = ADC_SAMPLETIME_64CYCLES_5;
 sConfig.SingleDiff = ADC_SINGLE_ENDED;
 sConfig.OffsetNumber = ADC_OFFSET_NONE;
 sConfig.Offset = 0;
 if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
  Error_Handler();
 /* USER CODE BEGIN ADC1_Init 2 */
 /* USER CODE END ADC1_Init 2 */
and function to read :
 ADC_ChannelConfTypeDef sConfig;
  uint32_t retval;
  HAL_StatusTypeDef result = HAL_OK;
  sConfig.Channel = ch;
  sConfig.Offset = 0;
  result = HAL_ADC_ConfigChannel(pAdc, &sConfig);
  HAL_ADC_MspInit(pAdc);
  result += HAL_ADC_Start(pAdc);
  result += HAL_ADC_PollForConversion(pAdc, 10);
  if(result != HAL_OK)
   printf("we are getting adc error result = %d",result);
  retval = HAL_ADC_GetValue(pAdc);
  HAL_ADC_Stop(pAdc);
  retval = (retval * ADC_CORRECTION);
  sConfig.Rank = ADC_REGULAR_RANK_2;
  sConfig.Offset = 0;
  return retval;
And the values I am getting is (expected 4095) :
4095
4788
4788
4790
4790
4788
4790
4095
4790
4790
4095
4790
4790
why the data is changing.
and I am reading 7 channels in independent mode with single conversion.
-Shrikant
Imen GH
Apr 10, 2020 10:45 AM UTC
​Hello,
Which product you used ?
Shrikant Patel_2
Apr 10, 2020 10:48 AM UTC
I am using stm32h7543
