ADC read error after updating to new version of cubemx 5.6
2020-03-12 5:51 AM
Hi I am using below configuration to read adc channels but I get some good values and some very bad values.
My configurations are :
void MX_ADC1_Init(void)
/* USER CODE BEGIN ADC1_Init 0 */
/* USER CODE END ADC1_Init 0 */
ADC_MultiModeTypeDef multimode = {0};
ADC_ChannelConfTypeDef sConfig = {0};
/* USER CODE BEGIN ADC1_Init 1 */
/* USER CODE END ADC1_Init 1 */
/** Common config
hadc1.Instance = ADC1;
hadc1.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV8;
hadc1.Init.Resolution = ADC_RESOLUTION_12B;
hadc1.Init.ScanConvMode = ADC_SCAN_DISABLE;
hadc1.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
hadc1.Init.LowPowerAutoWait = DISABLE;
hadc1.Init.ContinuousConvMode = DISABLE;
hadc1.Init.NbrOfConversion = 1;
hadc1.Init.DiscontinuousConvMode = DISABLE;
hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
hadc1.Init.ConversionDataManagement = ADC_CONVERSIONDATA_DR;
hadc1.Init.Overrun = ADC_OVR_DATA_OVERWRITTEN;
hadc1.Init.LeftBitShift = ADC_LEFTBITSHIFT_NONE;
hadc1.Init.OversamplingMode = DISABLE;
if (HAL_ADC_Init(&hadc1) != HAL_OK)
Error_Handler();
/** Configure the ADC multi-mode
multimode.Mode = ADC_MODE_INDEPENDENT;
if (HAL_ADCEx_MultiModeConfigChannel(&hadc1, &multimode) != HAL_OK)
Error_Handler();
/** Configure Regular Channel
sConfig.Channel = ADC_CHANNEL_3;
sConfig.Rank = ADC_REGULAR_RANK_1;
sConfig.SamplingTime = ADC_SAMPLETIME_64CYCLES_5;
sConfig.SingleDiff = ADC_SINGLE_ENDED;
sConfig.OffsetNumber = ADC_OFFSET_NONE;
sConfig.Offset = 0;
if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN ADC1_Init 2 */
/* USER CODE END ADC1_Init 2 */
and function to read :
ADC_ChannelConfTypeDef sConfig;
uint32_t retval;
HAL_StatusTypeDef result = HAL_OK;
sConfig.Channel = ch;
sConfig.Offset = 0;
result = HAL_ADC_ConfigChannel(pAdc, &sConfig);
HAL_ADC_MspInit(pAdc);
result += HAL_ADC_Start(pAdc);
result += HAL_ADC_PollForConversion(pAdc, 10);
if(result != HAL_OK)
printf("we are getting adc error result = %d",result);
retval = HAL_ADC_GetValue(pAdc);
HAL_ADC_Stop(pAdc);
retval = (retval * ADC_CORRECTION);
sConfig.Rank = ADC_REGULAR_RANK_2;
sConfig.Offset = 0;
return retval;
And the values I am getting is (expected 4095) :
4095
4788
4788
4790
4790
4788
4790
4095
4790
4790
4095
4790
4790
why the data is changing.
and I am reading 7 channels in independent mode with single conversion.
-Shrikant
ADC
STM32CubeMX
STM32H7 Series
2020-04-10 3:45 AM
Which product you used ?
2020-04-10 3:48 AM
I am using stm32h7543
