2026-01-28
3:03 AM
- last edited on
2026-01-28
4:40 AM
by
Lina_DABASINSKA
Hi Team,
Urgent help required!!
Today I have update my CubeIDE to the latest version, before the update i have had several projects saved, but none of it is launching in CubeIDE, when i click on the .IOC file from CubeIDE it opens on CubeMX and when i clock on generate code it says "The Code is successfully generated under :C:/Users/S****** H******/STM32CubeIDE/workspace_1.16.0/Door Module Testing" and as soon as i click on Open Project it goes to CubeIDE and shows main.c file. When I try to open the .IOC in CubeIDE it redirects to CubeMX again, a never ending loop has formed. Attaching screenshots for your review. Someone from ST Electronics please look into my issue and give me a quick fix or a workaround.
Prateek
2026-01-28 3:23 AM - edited 2026-01-28 3:24 AM
Hello @prateek and welcome to the ST community,
I assume to CubeIDE 2.0.0.
So please bear in mind that starting from CubeIDE 2.0.0 CubeMx has been removed from IDE.
From now on you need to use IDE and Mx separately and open ioc file from the stand alone version of CubeMx.
Refer to IDE Version 2.0.0 - why remove MX ?
STM32CubeIDE 2.0.0 workflow tutorial
