2022-01-10 7:06 AM
I searching the simple and usefull way to change wingets location for more flexible debug UI design. For example how to place the gauge first before and 20 pixels lower the chart on the dashboard?
The flow looks like:
2022-01-11 3:25 AM
HI
Fist you need to select dashboard on the right side
And then select layout to be able to modify widget location
Then you'll be able to place your widget where you want
2022-01-11 3:25 AM
HI
