X-NUCLEO-NFC08A1 bring up on NUCLEO-U575ZI-Q
IdSTM
I am fairly new to STM Cube IDE and the expansion packages.
I wanted to bring up the X-NUCLEO-NFC08A1 on NUCLEO-U575ZI-Q with the examples and read through several user guides etc. including the STMicroelectronics.X-CUBE-NFC6_GettingStarted. The documentation also has a fault by stating that the "Additional Software" button must be click which does not exist in the IDE. According to the https://www.st.com/en/evaluation-tools/st25-nfc-rfid-eval-boards.html webpage it should be possible.
I followed the starting guide that is provided when downloading the extension package (Getting started with the X-CUBE-NFC6 high performance HF reader/NFC initiator. IC software expansion for STM32Cube).
I followed the steps selecting the Nucleo-L476RG board during project creation for which examples are also provided.
In contrast to the guide it does not find a solution and it only offers PA5 for all LEDs.
I would appreciate if you could give a step by step guide to setup a project where I am able to select the right pins and peripherals.
Best regards,
Philipp
IdSTM
Hello again,
sorry for asking this question as an unexperienced user ;)
I solved it myself by configuring the GPIOs and the Peripherals as follows:
Hope this helps someone else who gets started with STM and NFC.
Best regards,
Philipp
IdSTM
Hello again,
Best regards,
Philipp
Hi
I'm also trying to configure the pins for the X-NUCLEO-NFC08A1. I want to use it with the NUCLEO-H533RE but i cant figure out how i shall configure the pins in a right way. Is there maybe a general solution for this? Or is there a different problem?
